Whirlpool dryer runs for 10 min then stops but timer keep running
Brand: Whirlpool
Model Number: Wed4815ew1
Main Symptom: stopping
What happens & when: When i set the Dryer to timed dry as i always do the dryer starts as usual runs turns gets hot everything. After 10 or 20 mins it stops. The timer keeps running till it hits the off position the dryer has never just started again during the period. I’ve replaced the heating element and all the sensor with one of those kits off amazon. Then the motor. Still not working I’ve tested the timer the door switch everything checks out. I’ve even tested the outlet and that read 240v and please nobody suggest lent. I’ve opened the dryer up no less then 6 time believe me there’s no lent left
The dry seems to run through a couple loads relatively fine then stalls again for no apparent reason.
Parts or tests already tried: all thermal sensors and the Motor
It would be recommended to check the rollers and idler pulley. If the drum is dragging, it can cause the motor to overheat and cause the unit to shut down and not want to restart until it is cooled down enough.
Measure voltage on the timer contacts between T&2 and S when dryer stops working.If you have 120 volts.Timer is bad.
