You’re probably right. Though metal to metal contact without bearings, it’ll probably take long time before shaft gets worn. I guess somewhat makes sense also that if bearing was used, then it could potential to fail due to high temperature environment.
I’ll take my dryer apart this weekend for replacement, so i’ll confirm the originals as well.
thanks again, this site and you guys are awesome! cheers.
