I have a whirlpool ultimate care 2 Dryer that will not come on. the timer ticks.The light comes on inside, but when I push to start nothing happens.
Hi. Our techs will be happy to provide help, but first please post your dryer model number (open the door, the tag should be right there on the front panel). Thanks.
Model number LE08857HZl
Thanks. The model is actually LEQ8857HZ1
Light on + timer ticking tells us the dryer has power, so something in the start-up chain is open. On this model the three parts that fail most often are:
- Thermal fuse (white, two wires, on the blower housing). Unplug dryer, pull one wire, meter it for continuity. Open = blown. Replace the fuse and clear the vent or it will blow again.
- Door-switch motor contacts. The light circuit can still work even if the motor side of the switch is bad. Door closed → COM to NO should read 0 Ω. If it reads open, replace the switch.
- Push-to-start switch in the console. While you press the button the two terminals must read closed. If they stay open, swap the switch (or fix the wiring).
Let us know what you find and we can walk you through the next step.
