Our Whirlpool dryer is not drying, there is no production of heat.
Is there a component that I need to replace?
Replacement parts for WHIRLPOOL LTE6234DQ4 Washer/dryer Laundry System | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%208546674.pdf
Here is a manual which may be close to yours
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/7d322131b309497a852571ca006ce7d2/$FILE/L-56_4314124A.pdf
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
If power is OK
Then next check the heater for resistance with a meter.
If OK then the heater’s thermal fuse.
If this is open get back to us as there are other things that should be checked to find out why it blew.
