Whirlpool Double Oven
There is nothing showing on the touch panel. We turned off the circuit breaker for about 10 minutes and nothing happened when flipped back on. When we open the upper oven door the interior lights for both ovens turn on (but when we open the bottom oven nothing turns on). We can press on the “buttons” and we hear beeps and when we touch light the interior lights come on.
Is this the control board that needs replacing?
Parts for Whirlpool RBD305PRS00 Oven - AppliancePartsPros.com
Following is a service manual.
You will have to join the site and be logged in to be able to download it.
http://appliancejunk.com/forums/index.php?action=downloads;sa=downfile&id=169;t=1412097524
Yes it does sound like a control board problem.
I would check the control thermal fuse for 0 ohms.
Would also be a good idea to check the primary and secondary resistances of the control transformer.
Well, the oven came back on and has worked for a couple of weeks. When it came on error code f2 e5 was showing. My husband pressed buttons (:/) and it has been working since then until tonight. Does it still sound like the control board? Thanks for the help.
Oops!!
I just noticed that I did not attach the tech sheet.
So will attach it now.
F2E5 is a key/connectioon or a control board problem.
I cannot say which part is the problem.
Unfortunately they do not publish a pin out for the keypad so it is difficult to check.
Perhaps the following will help.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
RBD305.pdf (504.2 KB)
Thank you. Will try all this before buying the control board.
