Whirlpool double oven
I have the Whirlpool double oven which I love. I just started getting the E6-F2 where the clock should be. It came back a few times and now it is one big blank. I need my ovens as the holidays are coming. Can you help me?
Thank you
Hello Based on the error code you provided, you will need to: [FONT=Helvetica][SIZE=2]
[LEFT]1. Check keypad connector for firm connection.
2. Press CANCEL. If error code returns after 60 sec., replace keypad.[/LEFT]
3. Replace control. Hope this helps.
AP6012597
AP6021414
Control panel parts replacement parts for WHIRLPOOL RBD245PDB14 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER | AppliancePartsPros.com
[/SIZE][/FONT]
