Whirlpool Door handle fell off
The door handle on my Whirlpool oven fell off, the screws were loose and I was unable to reach them inside the oven door. Can this handle be reattached without taking the door off? If so or not can someone please tell me the steps to take to reattach the door handle? Your help is greatly appreciated. Thank you.
Unfortunately you have to disassemble the door in order to reattach the door handle. The door has to be removed from the oven as described in the Owners manual (page 12).
Put the door on a flat surface with the door front facing down, remove the screws holding the door liner and remove the liner.
Here are the break down diagrams and Replacement parts for WHIRLPOOL RBS305PRS00 | AppliancePartsPros.com
Thanks Gene,
I am going to tackle the door this weekend. Will let you know how it goes, the drawings and manual will be a great help.
Mike
Gene,
Thank you for your help, the drawings and your expertise made this repair so easy. Again thank you.
Mike
Mike,
