The dishwasher appears to have no power. The outlet works fine. It just stopped working one day. Any ideas, I’m pretty handy once I get headed in the right direction
Replacement parts for WHIRLPOOL DU945PWPQ2 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208535431.pdf
A possibility is the fuse, Item 4 in the “Frame and console” section
Next would be the door latch switches
The above assumes that power is getting into the unit and it is not just a bad wire nut connection.
[quote=denman;132335]Here are your parts
There is a good STICKY at the start of this forum about it’s use.[/quote]
hEY THERE, THE TECH SHEET FOR THIS DISHWASHER IS NO LONGER AVAILABLE HERE? ANYWAY YOU CAN SEND ME A LINK FOR ANOTHER ONE PLEASE? THANK YOU
Please see the attachment
DU945.pdf (194.8 KB)
My wife went to wash dishes the other day and the whirlpool dishwasher filled up but would not start wash cycle nor drain when I pushed cancel. I checked for clog in hoses. Any suggestons where to start?
You have to do more troubleshooting.
Does the unit seem totally dead?
If yes then the thermal fuse may have blown.
Is the pump getting voltage but not starting?
