My built in Whirlpool Dishwasher has a flashing rinse only light. I can not get any of the controls to work. I have checked the internal fuse(ok). I have also checked the door safety switches (ok). I have removed power and turned back on but does the same thing, just a flashing rinse only indicator. I think it might have a bad control circuit board. Any ideas???
[COLOR=Blue]I think it might have a bad control circuit board.[/COLOR]
I would lean more towards a stuck closed key.
See the tech sheet to get the keypad pinouts so you can check it with your meter.
