Whirlpool dishwasher
I have a whirlpool dishwasher that stopped working today.I have power going to the control panel and the door switch seems to be working but nothing works.None of the buttons on the front work.The lights did flicker once but that was it.Any advice?
i have the problem of the dish water is spitting water in to the basement and the spray nozzle is not getting enough pressure to spin it. i ask there is a pressure ring under it is it suppose to be hole or is it suppose to have a common i shaped crack in it
catjay,
Did you check the thermal fuse (#4 on the break down diagram) for continuity?
ineedhelp123,
What is the complete model number of the dishwasher?
gene.
catjay
Here is a tech sheet for your unit
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208535431.pdf
