Whirlpool dishwasher won't start
Brand:Whirlpool
Model Number: WPF320PADS3
Main Symptom: Lights come on but won’t start
What happens & when: Place in start, hear something, then stalls. Replace Control board and door sw has continuity. Previously replaced water inlet valve and heating element.
Error Code (if any): 4-3 and 5-2
Parts or tests already tried: Control board, door switch has continuity. Last year heating element and water inlet valve.
Thanks for the details! Since your Whirlpool dishwasher WPF320PADS3 lights up but won’t start, and you’ve already replaced the main control board, I wouldn’t recommend replacing any more parts just yet.
The two error codes give us a good starting point:
  • F4E3 (4-3): Wash motor not running. This can indicate a problem with the circulation pump, its wiring, or the power being supplied to it.
  • F5E2 (5-2): Door switch or door lock problem. The control may not be recognizing that the door is properly closed.
The fact that you hear something when pressing Start, but then the dishwasher stalls, makes me particularly interested in the wash motor.
Here’s what I’d check next.
1. Check the door latch and switch.
Even though your door switch passed a continuity test, we still need to make sure the control recognizes the door as closed. With the power disconnected, inspect the latch, wiring, and connectors. Check that the switch changes continuity when operated and that the door closes securely.
2. Check whether the dishwasher fills with water.
Start a normal wash cycle and listen carefully. Does the dishwasher fill with water before stopping, or does it stall almost immediately?
If it fills but never starts spraying water, that would make the circulation pump a stronger suspect.
3. Check the circulation pump.
Disconnect power before inspecting the pump and wiring underneath the dishwasher. Look for loose connections, damaged wires, or signs of overheating.
If the pump is receiving the proper operating voltage when the control calls for washing but doesn’t run, that would point toward a faulty pump or an obstruction. This is a live-voltage test, so it should only be performed if you’re comfortable working safely around energized electrical components.
One thing I’d like to clarify
When you press Start and hear that noise, does the dishwasher actually fill with water, or do you just hear a humming or clicking sound before everything stops?
Also, does the Start light begin flashing, or does the dishwasher simply sit there with the lights on?
Those two details will help us determine whether to concentrate on the door latch circuit or the circulation pump before spending money on another part.
