After completing the last cycle fully, the machine won’t run any more. I checked the door switch and it had continuity and voltage running into the tan and red wires. I also checked the TCU fuse and its fine (continuity and voltage present). However, when I trigger the door switch, the voltage drops to zero.
What should I be checking next to troubleshoot the inability to start the machine?
[COLOR=Blue]However, when I trigger the door switch, the voltage drops to zero.[/COLOR]
Not sure what this means, where are your meter leads connected?
Also I do not see a red wire on the diagrams.
Both switches must close to get power to the board.
I would measure the voltage at the board (P7 white/violet to P8 tan).
I measured the voltage on the door switch on the metal where the wires touch the interrupter. I meant to say I used the black / tan wires. Now, I will check on the P7/P8 terminals and let you know.
I checked the power coming into the junction box under the machine and it is at 120V. The wires are properly twisted together behind the plastic wire nuts and the ground is attached.
The strange voltage you saw earlier would indicate that you may have a problem with the wires going from the line connection point up to the switches/board etc.
I would check from the tan on the one switch to the white/violet on the other switch. With both switches closed you should get 120 volts.
if OK
I would go back and recheck this.
Also should be 120 volts.
