Dishwasher won’t drain at end of cycle. Installed new drain pump, voltage verified @ 118v to pump wires. Pump runs, and partially drains thru-out cycle, but leaves a couple of inches of dirty water in the bottom after all cycles completed. drain hose not plugged or kinked. when drain hose is run into a bucket, very little pump pressure present. Entire wash&rinse cyles completed, only @ 1 gallon of water in bucket.
KDC,
Did you remove and check, clean the two filter plates in the bottom of the tub, under the spray arm ?
Did you check the pump sump for crud or debris in the sump housing ?
And you’re sure you orderred the correct drain pump assembly
And you checked the connecting hose assembly for debris ?
There’s not much left after these checks and repairs, other than a clogged,twisted,kinked drain hose.
Good Luck,
Pulled it all back apart, found a paper label blocking the drain back “flapper” (red rubber), between the rubber housing and the drain pump/solenoid assembly. removed label, all working good now. Thank you!
Kdc4runner
[quote=kdc4runner;302012]Pulled it all back apart, found a paper label blocking the drain back “flapper” (red rubber), between the rubber housing and the drain pump/solenoid assembly. removed label, all working good now. Thank you!
Kdc4runner[/quote]
KDC,
Great job,
We’re happy we could help,
You’re welcome.
