My 6 year old whirlpool disherwasher will continually keep running the washing cycle timer dosen’t count down. What part would I need to try to fix this myself?:mad:
As part of normal operation, the dishwasher pauses 2 or 3 times during the cycle for thermal holds and advances once temperature is met. If the inlet water temperature is less than 120°F, it could take up to 3 1/2 hours to finish a cycle.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GU2700XTSB1 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
[quote=Gene;402240]As part of normal operation, the dishwasher pauses 2 or 3 times during the cycle for thermal holds and advances once temperature is met. If the inlet water temperature is less than 120°F, it could take up to 3 1/2 hours to finish a cycle.
Gene.[/quote]
Not sure thats the problem its been working fine just started this 2 nights ago:mad:
Did you see the “Clean” light blinking?
Did you check the water temperature inside the dishwasher?
