Whirlpool Dishwasher Stops after first cycle
Brand:Whirlpool
Model Number:WDF320PADB3
Main Symptom:Will Not Wash Dishes or Shut off at Control Panel
What happens & when:Won’t Clean and Shut off
What happens & when:Good morning. I’m having issues with my Whirlpool dishwasher model # WDF320PADB3. The first issue started when I noticed that a few dishes came out, filthy after my wife had turned the dishwasher on, and it apparently went through the cycles overnight and it completed all cycles. We were in bed unnoticed if water had been entering and leaving the dishwasher. The next time I noticed that I had turned on the dishwasher and the first cycle started, and it filled with water and then that was it all the lights had remained on and the dishwasher did not complete any more cycles at that point I knew something was wrong. That was approximately one and a half weeks ago. This past weekend I went out to my circuit breaker turned it off for approximately 20 seconds turned it back on and turned the dishwasher on with nothing in it when it goes through the cycles observed it listened to it all the lights apparently worked which they had before. Listening to it it went through all the cycles heard water going through it this time however it remained on with all the lights after having gone through all the cycles and again remained on for approximately five hours, approximately 1 1/2 hours longer than normal. At this point I hit the cancel button, opened up the dishwasher and noticed that it was not warm or hot inside, which was not usual as when I would normally open it would be warm at least unless it was after an overnight cycle and there was a lot of condensation inside on the door panel.
