Whirlpool Dishwasher Start Normal cycle help
I have a Whirlpool Dishwasher Model # du927qwdb1.
  1. It was working fine all these days, but now I cannot start the NORMAL cylce. 2. If I start “Pots n Pans” Cylce the dishwasher works.
  2. I did try lockout by holding Airdry button for a min and press cancel, then press " Normal " button, it does not work.
  3. I did try resettting and power off then on also.
Please help me out with this issue.:o
Replacement parts for WHIRLPOOL DU927QWDB1 | AppliancePartsPros.com
Here is a tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%203379195.pdf
Try removing power from the unit for 10 minutes or so to see if it will reset.
Check out the tech sheet to be sure you are not stuck in a diagnostics mode.
Check what other keys may work, this may help narrow down the cause.
Could be the normal key is toast. Check the control panel/keyboard with a meter.
NOTE: The keypad is a matrix type (has diodes) so the meter polarity matters when checking the key. With the negative lead on P1-3, the positive lead on P1-12 and the meter set to a mid-range scale the resistance should drop to close to 0 ohms when the key is pressed.
You may want to try the following
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
