Whirlpool dishwasher replacement rack #3369903
I purchased a replacement upper dishrack, #3369903, for my whirlpool dishwasher from FSP parts. The package of attachment parts did not contain a set of instructions for assembly as the lower rack did , #8193771. The attachment parts are much different than the original, therefore I need some assistance on figuring out how to assemble the bag of parts. The picture you have in your system of Part #3369903 shows a page of instructions in the bag. Please help with some instructions!!!
admin note: see below
Call FSP parts!!!
OR
Add a Model Number to your post perhaps the instructions are available as a tech bulletin.
I have same problem. Perhgaps the parts people need some instructions on including the instructions.
See attachment for instructions
3369903.pdf (1.3 MB)
IT would be nice to know how to assemble this bag of seemingly unrelated parts.:mad:
I too am having problems installing the upper dishwasher rack 3369903. I got a PDF from your site marked 8194593 1/07. It does not match my new rack and I can’t get the adjustable support arms installed. There is interference from the rack frame wire on the lower outside. The photos are not my new rack. Do you have a better instruction for my part? Thanks!
Mine was also a little different. but if I set up the higher wall side as front, then the whole parts assembled and I was able to install it into my washer.
check here for the instruction sheet:
www.*******.com/file/133544/
The Service Matters link suggested by this Site leads to a dead website. See my note, above.
[QUOTE=RICHARD WATMAN;774423]check here for the instruction sheet:
www.*******.com/file/133544/[/QUOTE]
Dear Richard,
The correct instruction sheet for the upper rack part# 3369903 is the above literature pdf#8194593 provided by the manufacturer Whirlpool.
If you did not receive the same rack pictured in the instructions please call us toll free at 1-877-477-7278 just in case you received a mispack.
Thank You
