Hello,
I have a 2 year old dishwasher that is not drying properly and the water temp is too low. About a month ago I noticed the clean light issue so I resetted it a couple times and havent had an issue where the dishwasher stops mid cycle. Below are my issues and what troubleshooting I have done in the past month.
Issues: Dishes not dry, intermittent soap residue on dishes, dirty dishes not clean, etc
Troubleshooting: After reviewing several blogs and boards here is what I did.
- Ensure hot water source is working into dishwasher-OK
- Check for blockage- OK no blockage
- Checked for continuity on element- passed has continuity
- Check for continuity on thermostat-passed has continuity
- Check door switch for contact- passed
- Ensure dishwasher is level and installed-OK
So after this, it was my assumption that I have a bad board. I just installed a new board which cost around $75.00 and I STILL HAVE THE SAME ISSUES.
At this point, I not sure if I should buy a new heating element or what else to do. I checked all of the connections and have continuity. PLEASE HELP…
Jason
