Whirlpool dishwasher motor pump replacement
I need help locating the correct motor pump assembly for the GU2400xtpb6 model. How difficult is this replacement? I am going to attempt it myself. Thanks, Kim
I think you are looking for this [part]AP3778061[/part]
Its not too bad of a job. Its probably easiest to remove the dishwasher from under the counter. Take off the pump, wires, and pull the three wedges that hold the pump in place. Oh, before you do that, you should remove the feed tube assembly and pump top inside the dishwasher.
This should show you how it goes together. Replacement parts for WHIRLPOOL GU2400XTPB6 Dishwasher | AppliancePartsPros.com
