Whirlpool dishwasher leaking from door
I have a whirlpool dishwasher that’s leaking from the bottom of the door, it leaks from both corners. I get suds and water on the floor. I just replaced the door seal thinking it would fix the issue but there is little to no change, i also tightened the screws on the inner door panel hoping that may have been the issue.
Thanks for any help,
Phil
There shouldn’t be much suds. Dishwashing soap doesn’t suds up. Perhaps you have residue from the soap left when you washed off the dishes before you put the dishes in the dishwasher? Just my two cents. Best of luck!
The suds are not the issue, the dishwasher that is leaking water is. It shouldn’t matter if I put dish soap in there(which I don’t) it should not be leaking onto the floor. Is there another seal or gasket I should look at?
I had the same issue. It turned out that food particles had jammed the (flood) float. The float, when the water reaches a certain height stops the water flow. If the float stick the water flow doesn’t stop. A good way to check for that is to see how deep the water is at the float housing. If it is over two inches or so it could be the float is jammed or the float switch isn’t working. My experience tells me that it will rarely be the float switch, that type of switch rarely fails.
