Hello,
Yesterday it seems my dishwasher broke and I’m unsure what the issue might be?
When you close the door and hit a button nothing happens at all. No lights.
I’ve tested the outlet it’s plugged into and it works just fine. I checked the power cord connections to dishwasher and they are solid. I also unplugged the dishwasher for a period of time to reset and that didn’t work. on the upper door is W10632077A. I can’t seem to find anything for this model which is odd cause it’s not that old. I’ve read it could be a fuse gone bad for this type of issue but I’m not seeing that when I take cover off the circuit board, unless it is somewhere else?
Any suggestions on what I might be able to do to find the problem? When I put my ear to the circuit board I hear a faint whine/beep sound over and over. Hard to explain.
Thank you
