Help, My Whirlpool Dishwasher is not working properly. I set the cycle, turn it on, the tub fills and the motor begins to run and then stops, a few minutes later it starts again for less than a minute and stops again. There is power the whole time and the timer is still on running through the entire cycles but nothing ends up clean. The heating coil is on, and gets hot. But the water doesn’t come out of the motor pump only but a minute every so once in a while. I can’t afford a repairman. I hope some one can help me, the dishes are piling up, soon to be Mt. Everest here in PA!:eek:
you motor overloads are kicking out. Sounds like you need a motor.
