Whirlpool cord change
I just changed the cord on my whirlpool from four prong to three. I plugged it in and started a load of clothes. Everything was fine for about thirty minutes. I then noticed it didn’t seem hot. I opened the door to stop the dryer and check. Sure enough the dryer had quit heating. Once I closed the door and tried again now nothing will come on. PLease help
A model number may help others help you.
Did you install or reconnect the ground strap from the unit’s frame to the Neutral connection on the terminal strip?
Re-check your connections.
wed4900xwo
There was already a wire connected to the nuetral section. I runs from the center connection to the frame. What should I do? Did I burn something up?
I checked my connection and I now have a tumbling dryer, but no heat and the timer does not seem to me working
Sounds like the original 4 wire cord was wired wrong.
The ground strap should have been disconnected for 4 wire as the Neutral and earth ground (machine frame) are separate.
What should I do?
Do you have a meter and some experience measuring voltage?
I cannot say but I would doubt it as there were no arc and sparks and the circuit breaker did not trip.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
[COLOR=“Red”]Be careful as 240 volts is lethal !!! [/COLOR]
I could not find any tech info on this unit.
You may want to take a look in the control console to see if they have stoer a wiring diagram in there.
thank you for your help!
