Whirlpool cookstove
Is there a fuse in this type stove…the stove is plugged in but the stove nor the oven will work
Replacement parts for WHIRLPOOL RF365PXYW2 ELECTRIC RANGE | AppliancePartsPros.com
See the attachment for the wiring diagram.
There is not a fuse/breaker in the unit so odds are there is a problem with the power getting to the unit.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
[COLOR=“Red”]Be careful as 240 volts is lethal !!![/COLOR]
RF365.pdf (24.8 KB)
