This is an electric oven. It will not go into Clean Mode. When I turn the dial to “Clean”, a red light below the Clean light blinks. The wording next to the light says “If light is blinking, close oven door”. Also, the locking mechanism does not lock the oven door.
However, the door appears to be closing correctly and the oven light goes off when the door is closed. So the switch that turns the light on and off is working.
How do I troubleshoot the problem? Thanks for your help.
Take a look at the latch mechanism (item 6 in section 03).
If you click on the picture or description a new page will open with more info about the part.
Sounds like either the control board is not powering the latch motor or the latch motor is bad. RF366.pdf (191.2 KB)
