Okay, so, I am on week 2 of the same issue. About 2 weeks ago, after NO issues at all (with the exception of the occasional unbalanced load) I started a load before bed and woke up in the middle of the night to an Ld error… after reading all the posts and taking the washer completely apart to find absolutely no blockages what so ever in the drains… I replaced the drain pump. Nope… no luck.. still would not drain or spin… so in my infinite wisdom, I decided the smart thing to do would be to replace the computer board. The part came today.. Yay! So excited.. I would finally NOT have to go tp the laundry mat ever again. I watched all the videos, took pictures of the placement of ALL the wires.. took off the old computer board.. installed the new one in about 15 minutes… and started the washer… and yep, you guessed it.. same issue.. except this time, with the no spinning and no draining, I got an Sd error… so, I unplugged it.. drained some of the water myself with my trusty shopvac.. and started it again… only this time… F1!!! WTH??? So… here I am.. what now??? PLEASE help!!!![]()
did you check the rubber hose to the control board?
disconnect it from the control board. you should be able to blow through it. it should not be pinched or cut.Did you run the calibrate after installing the control board?
So I seem to be in the same issue as Mrs. C. I am continually getting the F32 error code. I’ve replace the stator plate and the RPS board. The pump is clear, the hoses are clear, and i have reset the calibration.
Every part runs fine on the manual diagnostic, but every time I get to C8 on the automatic diagnostic it stalls and will not get to the spin part, it just stays stuck in the drain.
Are there any other solutions that I have not thought of that anyone can think of? I am dying here
