Whirlpool cabrio washer
I have a problem with my washer. It leaks around the time it is supposed to drain anid the leak seems to be coming from just above where the drain pump is located. Any ideas?
It is probably a leak in the hose that leads to the pump, or where the hose connects to the pump.
