Whirlpool Cabrio Drum Mounting Hub replacement options
Hello! While troubleshooting my Whirlpool Cabrio washer for a clicking noise and not spinning during wash cycles, we found that the Spanner nut and hub pieces had corroded pretty badly and need replacing. Rust Buster and CLR cleaned it up a bit, but not enough to loosen the pieces for removal, so it’ll need cutting.
However, the replacement part kit #w10334651 is basically out of stock and back ordered everywhere we’ve looked. We’ve found some plastic pieces of a similar size we can maybe cobble together, but not a full plastic replacement kit.
Does anyone know if we should hold out for the month+ it could take to get the metal kit in stock, or if there is a proper set of plastic replacements for this washer?
Additional info on this washer: The impeller was the part not working
Cabrio Washer: model WTW5640XW0
Plastic hub kits we bought in desperation: W10528947 and W10820039
