I am trying to order a replacement part for model mh6150xlq0 Whirlpool built-in microwave. The original grille vent installs with a few screws above the microwave door. The part # AP3855006, $44.88 was recommended as a replacement, but no information was available for how the part is installed.
Can you confirm that the part installs with a few small screws???
[quote=RASlifkin;278862]I am trying to order a replacement part for model #MH6150XLQ0 Whirlpool built-in microwave. The original grille vent installs with a few screws above the microwave door. The part # AP3855006, $44.88 was recommended as a replacement, but no information was available for how the part is installed.
thx.[/quote]
Ras,
Based on your information AP3855006 is a white colored upper vent trim.
It is a direct replacement part for the existing trim on your unit, and will mount to the cabinet with screws on the top and tabs on the bottom.
Thanks for your help, Joe. I’ll place the order right away.
