Whirlpool belt-drive washer
Here’s what it is DOING:
[LIST]
  • WATER FILLS
  • MOTOR RUNS
  • AGITATES
  • TIMER DIAL ADVANCES AND WON’T STOP (I manualy pull the knob to stop it.[/LIST]Here’s what it is DOING:
    [LIST]
  • WATER WON’T DRAIN
  • WON’T SPIN: WHEN DIAL ADVANCES TO SPIN CYCLE, IT WON’T SPIN, THERE IS A HUMMING SOUND[/LIST]Can you diagnose the problem based on description above? What part do you think I need?
Thanks,
Florian
I would pull the cover off the timer and look for burnt points. If so, you need a new timer.
The Whirlpool # is 660750. This sites # is AP2915208.
Both sites I checked show it is no longer available.
You can get this timer repaired. There are on line sites that do this, just crunch in google for them.
