The dryer works, but it tells me that the filter needs cleaned when I go to select a cycle.
I’ve cleaned the lint trap. And it still says it. What other filter should I be cleaning?
[QUOTE=jlo3810;840341]The dryer works, but it tells me that the filter needs cleaned when I go to select a cycle.
I’ve cleaned the lint trap. And it still says it. What other filter should I be [COLOR=“Black”]Gold Coast upholstery cleaning[/COLOR]?[/QUOTE]
Have you got the booklet that comes along with the drier? I think if you check carefully you will come to know what other sections you need to clean.. I hope it will help you..
