Whirlpool accubake oven isnt working
I got the oven from someone they said it didnt work, well long story short all the lights and everything works on control panel but the oven elements won’t work you can set the timer the temp and all that it counts down but it won’t heat up but when i do the auto clean the oven will work then and only then
When it’s in auto-clean are both elements working?
If the lower one is broken, it won’t heat on bake, but it only when it’s set on broil or auto-clean.
