Machine will not spin or agitate makes a slight knocking noise. lid switch is slightly bend which may prevent the spin and agitating but not the knocking noise.
Hi.
Can you tell where is the knocking noise is coming from?
Does the water fills in?
Does the door locks?
Simon.
[quote=Simon / APP Team;807615]Hi.
Simon.[/quote]
the washer will not due anything except drain. when I turn pully to see if it was free, noise inside drum. drum turns free
Hi.
I’d pull out the lid switch to check it’s damage.
Simon.
