Whirlepool dishwasher won,t fill on rinse
Dishwasher seems to work in all ways except it doesn’t fill on rinse cycle. It goes through the motions & makes all the sounds-just no water to push. Enlighten me please, Ye Experts!
Check the water valve at the rinse cycle and you should have 120v going to it to allow water in. Check the main board and see if you have 120v going out to the water valve wires if you dont you have a bad main board.
Video’s to watch
dishwasher won't fill with water on rinse - YouTube
[quote=HumboldtRepairMan;830227]Check the water valve at the rinse cycle and you should have 120v going to it to allow water in. Check the main board and see if you have 120v going out to the water valve wires if you dont you have a bad main board.
Video’s to watch
dishwasher won’t fill with water on rinse - YouTube[/quote]
Thanks! Going to try this ASAP!
