When the oven light switch is activated, the oven light does not illuminate- maybe needs new bulb- I can’t locate the oven lamp light bulb. Any help is appreciated.
Thnx, Ray
Thnx, Ray
Hy Ray,
You can find the complete instructions in the “Owner Manual” (page 40).
Here are the break down diagrams for the Jenn Air range Model SCE4340W
Gene, thank you very much, found and changed the bulb. ![]()
You’re welcome. I’m glad you were able to fix it.
