I was in the process of checking for bad dog-ears on upper agitator when I noticed if I pull the agitator in various directions the tub easily leaned over but did not readily center itself.
I haven’t had major problem with it wobbling when spinning though I have my share of it with towel/heavy loads.
Just wanted to check if something was going wrong with the suspension.
I checked parts diagram but can’t figure out where I will find these suspension springs. What do I need to take off to locate them. Top, Bottom?
Thanks,
TomAllThumbs
