Where do I start Jenn Air Defrost Problem
From reading all of the posts I believe I have a bad defrost element or thermostat. I know I need to remove the back panel from the freezer compartment but dont know where to start. There are side rails and an ice maker in the way of the panel. Can someone get me started?
Replacement parts for JBL2088HE5 models | AppliancePartsPros.com
I could not find any info on the given model number so used HES5. It should be a close match to your unit.
Here is a service manual.
http://appliancedigest.com/index.php?/files/go/84097668701ba731b86fb5a591967a8b/16025629-maytag-amana-bottom-mount-refrigerator-service-manual
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle (see the tech sheet)
When the fans and compressor turn off you are in defrost.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the contyrol board needs replacing
If not on.
Unplug the unit.
Remove the wire for one side of the heating element from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the control board is toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
JBL2088.pdf (917.5 KB)
