When opening dishwasher the pan is leaking water
We had a leak caused by the inside right side covering the white disk (sensor??). Since than when you open up the dishwasher it leaks water out of the pan. Do we need to clean it out and if so how do you remove it or clean it?
What is the complete model number of the dishwasher?
