I had the bake element go on my stove. I bought the replacement and it wouldn’t work. Someone suggested testing the high limit switch for continuity. After some difficulty locating it I found it (thanks to bf1) and it tested fine. So… Where do I go next to fix this stove? I also tested the oven sensor (fine).
Thanks denman. In your opinion, and anyone else, I see a relay board is going to cost me over $200. Plus another $60 or so for the element. Would you spend that for a 10 year old stove?
[QUOTE=edee_em;182780]Thanks denman. In your opinion, and anyone else, I see a relay board is going to cost me over $200. Plus another $60 or so for the element. Would you spend that for a 10 year old stove?[/QUOTE]
IMHO (for what it’s worth) it depends on what type of range you would replace it with. If you gonna replace it with a $399 special from Home Depot, then no, it’s not worth it to spend $250 on a 10 year old model. If you will replace it with a $2000 high end model, then maybe so. Jennaire is a pretty high end brand. I had a range that lasted 20+ years one time with little trouble.
When you decide, post it up. I’ll be curious to see what you decide. I’m going through a similar struggle right now.
[quote=cooney;182903]IMHO (for what it’s worth) it depends on what type of range you would replace it with. If you gonna replace it with a $399 special from Home Depot, then no, it’s not worth it to spend $250 on a 10 year old model. If you will replace it with a $2000 high end model, then maybe so. Jennaire is a pretty high end brand. I had a range that lasted 20+ years one time with little trouble.
Good luck![/quote]
I decided on not repairing it. There were two reasons: first, the cost and the fact that there was no guarantee the other board wasn’t going to go which would add another 80 or so. Second, I was trying to keep the stove as a second oven in a basement kitchen. But, for that purpose, I could buy a brand new stove for roughly the same dollars. So, to the curb it went! Good luck with your decision.
