The other day the resistor on my frigidaire dryer’s fabric selector switch burned in half. Me and my brother had crossed the wires while hooking it back up. The wiring diagram shows that it is 3 k ohm resistor, but not what type or what kind of watt (1/4,1/8,1/2,…) i need.
Replacement parts for FRIGIDAIRE GLER341AS2 Frigidaire/electric Dryer | AppliancePartsPros.com
Here is your wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Webster/131850600.pdf
Looking at the diagram, I assume you want to replace the resistor on the fabric selector switch. So if we use 240 volts across 31 K ohms (3 + 28) it works out to 1.9 watts so I would use at a 2 watt or better resistor.
