We are missing this part
Part Details - GE Valve, check, part number: AP2038495
Can you tell me what is does?
When in a wash mode, it closes so that all the water goes up the pump throat to the wash arms.
In a drain mode, it opens so that the water can drain back into the pump faster and be pumped out of the unit.
A symptom of this being no good is poor washing as some of the water is pumped out of the hole this covers instead of up to the wash arms.
Thank you so much. That clears it up!
[quote=denman;262911]When in a wash mode, it closes so that all the water goes up the pump throat to the wash arms.
A symptom of this being no good is poor washing as some of the water is pumped out of the hole this covers instead of up to the wash arms.[/quote]
