What is code F 21?
What does F 21 indicate?
The machine is draining so slowly that the CCU thinks there is a problem. There probably is.
This tech sheet will interpret the results for you, but I suggest you take off the bottom service panel and thoroughly clean out the pump and drain hoses and that will likely fix your problem.
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208183018.pdf
