Whaich part in heater circuit?
Hello,
My “Clean” light is flashing. The manual says this is a malfunction in heater circuit.
Anyone know if that means the heating element, the control panel or something else? If unsure, how to determine that? How do I test it?
Thanks…!!!1
Replacement parts for WHIRLPOOL DU1100XTPB6 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
Could be any of the items you listed.
First thing to try is to remove the power from the unit for 5 minutes or so to see if it will reset.
Look over the tech sheet and run any applicable tests.
If this does nothing check the heater and the hi-limit thermostat with a meter.
If OK
Check the wires from the heater/hi-limt up to the control board.
If all OK then it is likely the control board is shot.
GU2500.pdf (167.5 KB)
