Error code e2 water left in the bottom of basket and a grinding sound i believe there may be something cloged or the pump may need replacing my question is does the grinding sound mean a faulty pump
Brand: whirlpool Model Number: wet4024hw0 Main Symptom: e2 error code with grinding What happens & when:
Hello! Yes, a grinding sound combined with water remaining in the washer basket can indicate a failing drain pump, but I wouldn’t replace the pump just yet.
On your Whirlpool WET4024HW0 laundry center, the first thing I would suspect is something caught in the drain pump, such as a coin, hairpin, or other small object.
A grinding noise can happen when the pump motor is running but something is interfering with the impeller.
Here’s what I recommend checking first
Unplug the laundry center. If there’s standing water in the basket, remove as much as possible with a cup or wet/dry vacuum.
Inspect the drain hose. Check behind the machine for kinks or restrictions that could prevent water from draining.
Check the drain pump. You’ll need to access the pump near the bottom of the washer. Place towels underneath and disconnect the hoses to inspect for obstructions.
Inspect the pump impeller. Look for coins, debris, or broken impeller blades. The impeller may have some magnetic resistance when turned, but it shouldn’t be broken, jammed, or excessively loose.
Reassemble and test. If you remove an obstruction, reconnect everything and try a drain cycle.
If the grinding continues after removing any debris, or the impeller is damaged, I would lean toward replacing the drain pump.
What the E2 code means
On this model, E2 means the washer hasn’t drained properly after approximately 8 minutes. Whirlpool specifically recommends checking for drain restrictions.
Whirlpool
+1
One additional test
If you’re comfortable using a multimeter, the service information lists approximately 14–18 ohms across the disconnected drain pump motor terminals. An open or shorted reading would indicate a defective pump. A normal reading doesn’t rule out mechanical damage.
Sears PartsDirect
One question that will help narrow this down
Does the grinding sound happen only when the washer is trying to drain, or does it also happen during washing and spinning?
If it’s only during draining, that points much more strongly toward an obstruction or damaged drain pump. If it happens during agitation or spin, we’ll want to investigate the drive system before ordering parts.
