Wet mini fridge
I took water in my basement and it seems it got high enough to cause my CHEFMATE mini fridge to stop working. is there anything I can do to repair it?
I cannot find any info on this unit.
Also you did not say what if anything it is doing.
First check the power to the unit.
I am assuming that the unit got wet and was plugged in so odds are high that it is toast.
If the unit has a start relay/overload on the compressor remove it perhaps it has water in it.
You could unplug it and try to dry it out.
A hair dryer works well here heat the compressor up then let it cool down then do this again several times.
Check the compressor and start relay see the following link.
Appliance Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
Also here is a good link on basic fridge repair
http://www.applianceaid.com/frig.html
