WHEN I PRESS THE “BAKE” pad on oven, the temperature setting is too faint to read it…
[QUOTE]WHEN I PRESS THE “BAKE”…[/QUOTE]Is the display always too faint or just when you press bake? If always, there is likely a problem in the electronic control itself.
LINK > FEB756CESA Electronic Control
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
[QUOTE=Dan O.;105167]Is the display always too faint or just when you press bake? If always, there is likely a problem in the electronic control itself.
JMO
Dan O.
=D~~~~~~[/QUOTE]
The time display is visible (altho I don’t think its as bright as it used to be) the temperature setting is no more/no less visible when I press “Bake”
Is it different than the time display? If both are similar, the electronic control is likely the cause. If the time/temperature illumination is different, I don’t know what could cause that but I can’t see it being anything other than the control either.
JMO
Dan O.
=D~~~~~~
