wbvh6240FWW - in 'decimal' mode
OK, I had intermittent pausing on this machine and decided to run the diagnostic mode.
I ensured the power button was off and then unplugged the m achine for 30s.
I then pressed the signal-delay-signal-delay sequence within 30s of applying power and the machine made 2 short beeps and the display remained blank.
I pressed the power button and the display showed the cycle time in decimals of minutes.
The machine is empty, filter clean and I have tried to reset it by allowing it to remain unplugged for 30 minutes (or more).
Any thoughts? It was at least working before I started. Now when I attempt to run a cycle, it counts down with a short delay and beeps twice before resetting itself to display a cycle time e.g. rinse and spin - 1.8.
Thank you!
[SIZE=4]I have the same problem. I tried to go into test mode and all I get are two beeps and everything remains dark and the door does not lock. Any help would be greatly appreciated. [/SIZE]
how do I reboot my GE front loader? No error code , When I turn it on it goes to the wash cycle and the time reads 1:0.5 The door does not lock.
