I replaced the water valve part # 241734301 and I have not water coming into the water filter I checked the water coming from the wall and I got good pressure what could be bad?
Hi.
Check if there is 120VAC at the brown solenoid when the water lever is pressed. See if the water comes out of this solenoid valve (disconnect the tube).
Then check if the water filter is seated properly and all the tubes are in.
If everything checks OK - you may have the faulty water valve.
Thank you. Post the results.
Simon.
I cheked the brown cables that conects to the main relay when I push the water dispenser and I got 68vac why is that I only get 68vac instead of 120vac? thank you again.
What was the original problem?
Hi.
[RIGHT][/RIGHT]
Read more: http://forum.appliancepartspros.com/refrigerator-freezer-repair/481445-water-valve.html#ixzz1xjq538Rw
Simon
Read more: http://forum.appliancepartspros.com/refrigerator-freezer-repair/481445-water-valve.html#ixzz1xjpu3HZu
Read more: http://forum.appliancepartspros.com/refrigerator-freezer-repair/481445-water-valve.html#ixzz1xjowrDC3
[quote=Gene;743851]What was the original problem?
Gene.[/quote]
I’m afraid you did not see this question yet.
You may want to check the diodes as described in the attached file.
How to test the water fill system with diodes - 2.pdf (144.9 KB)
How to test the water fill system with diodes.pdf (554.2 KB)
