I am trying to replace my water valve. as my ice cubes did not work and repairman told me to replace the water valve. I order the part and it arrived friday. Part number is 4389177. I do not know where the hose go and if I turn the water on and plug in ,water comes out of the frzzer. I should have marked the hose’s but didnot. I can see where the one is smaller and it only fits one place. on the instructions that ame with the part it shows how to replace it but not how the water lines are. Any help would be appreciater
I just got a new water valve also. The icemaker hose is thinner than the wate dispenser hose. The 2 hoses go into the inlets above the solenoids[with the prongs]. The largest of the 4 inlets I believe is for your water line. Sorry, don’t know about the other inlet. I viewed your model # online. The ice maker hose should have water go into ice maker and maker stops flow into the tray. bjw
