Water Valve
Can you please tell me where the water valve AP2039339 is located and what I have to do to replace it?
Here is a parts breakdown
Model Search
It is behind the kick plate, left hand side.
Turn the water off and simply replace it.
Have a pan there to catch the water that will spill out.
Why do you want to replace it, if it is just because you have no water there are a number of other things that can cause this.
  1. Valve not getting power
  2. Overfill switch not working either, the switch or the float.
  3. Inlet filter screen in the valve is plugged
